Hello all,
I've been a member of the site for about a week now, and I am certainly hooked. I've been scanning the post's for some simple mods, and came across one for my 2C maglite. I installed (3) CR123's, and changed the lamp over to a KPR 113. It worked for about a second and then blew the bulb. I put another in, same thing. After some research, I found that maybe I should be using the KPR112, seeing it has a higher voltage capacity, 6 compared to 4.8.
Well, after visiting RadioShacK, I was only able to get a PR112, not the "K" Krypton version. I Installed and it worked fine. Well, I was out today passed another Radioshck, and found they had the KPR112 bulbs, so I bought one. I came home, installed it, and the samething happened, it burned out in about a second.
Am I missing something, or doing something wrong? The non Krypton version works fine? Would I see a big improvement even if I were able to not blow the "k" bulb?
Thanks in advance for any advice.
