thanks! i admit I thought the CPF special was brighter overall. looks like I'll get the AMILITE instead.onthebeam said:I'd suggest the Caribbean over the Peak special as an everyday carry. The special has much lower output unless using the rechargeables. Using the rechargeables, it's hotter and not as long running. So, it's a great show light for quick use but you'll have a dimmer light with the special if using it for a longer period of time. Also, the Caribbean pocket body is only 2.88 inch long--the red special is .5 inch longer.
I've had both. IMO a big advantage of the Caribbean (pocket body) is smaller size and longer run time (assuming L1P has alkaline). With an e2 AA in the L1P run time is about the same.jay7430 said:SO what are some of your thoughts? I know the Carribean is double the price, and seems the tested outputs are similar, but how does it perform in the real world?
Actually, there's a post that shows the Ranier doesn't necessarily run any hotter than the Caribbean. Forty minutes run-time has been plenty to get me through the daylight part of the day, so referring to it as a "show light" isn't really fair. (smirk) As for the lack of a pocket body for the CPF 2005 Special, i'd say that that's a reason to get the momentary switch, now isn't it?onthebeam said:I'd suggest the Caribbean over the Peak special as an everyday carry. The special has much lower output unless using the rechargeables. Using the rechargeables, it's hotter and not as long running. So, it's a great show light for quick use but you'll have a dimmer light with the special if using it for a longer period of time. Also, the Caribbean pocket body is only 2.88 inch long--the red special is .5 inch longer.
Archangel said:As for the lack of a pocket body for the CPF 2005 Special, i'd say that that's a reason to get the momentary switch, now isn't it?
joema said:"Your eyes are often poor judges of overall output."
Really? ....That doesn't make any sense! We do carry around these lights to SEE better do we not? I don't know about you, BUT my eyes are the final authority when it comes to "overall output" on any light.
Peace,
gil
2low said:joema said:"Your eyes are often poor judges of overall output."
Peace,
gil
Well, I guess he told you
