Introducing the Super MJLED - New Update
Introducing the Super MJLED, or SMJLED.
These are a direct plug in replacement for the bi-pin incandescent lamps used in popular two cell AA/AAA flashlights.
While the acronym is getting a little long, I couldn't think of a better way to describe these LEDs than as a Super version of the MJLED.
These are hi-power, super efficient quad die (four LEDs in one package!) 5mm LEDs that function as plug in bulbs for use in popular two cell AA/AAA flashlights. These have been reworked at the optics lab to have the their lens ground and polished into a low dome for use with reflectors.
These are even brighter than the original MJLED!
These have the same insane 35 hour run time to 50% initial brightness, but produce significantly more light.
SMJLEDs are in stock now, along with full drop in kits, SMJLED modified flashlights, and some new mod instructions.
The SMJLED webpage is located here:
SMJLED Webpage
If you missed out on the MJLED, or just wanted to get more, here's your chance to get an improved and brighter version.
Thanks for looking,
Lambda
SMJLED Webpage
Thanks for looking,
Lambda
