Welcome to CPF!
Can you fill out the location in your profile so people do not send you to Target to buy a River Rock 2AA.
The source charges too much for the flashlights they sell.
For example this
http://www.thesourcecc.com/estore/P...e&category=Flashlights_Luxeon&product=6119048
is the same as this
http://www.j2ledflashlight.com/tm303x.html
Both prices are in canadian dollars.
I would not buy a flashlight at the source unless it is on sale at least 1/3 off the regular price.
I do not have the flashlight you are considering. But.....
2AA does not give enough voltage to power leds. So a boost circuit is used. THe amount of light depends on the boost circuit as much as the led. When 3 watt leds became plentiful many manufactures switch to the 3 watt led (good advertising - I got a 3 watt instead of a 1 watt) but did not triple the power of the boost circuit. As a result the new flashlight is not much brighter than the old one. Buyer beware!
The 1 watt version of my price example above produces 20 lumens.
The 3 watt produces only 25 lumens, not the expected 20x3=60 lumens.
Do not get hung up by the 1 watt / 3 watt thing.Check the actual light output. Flashlight reviews is a good place to start.
http://www.flashlightreviews.com/
Hang around the furum for a bit and you will find much better choices. Or at least wait for The Source to lower the price from $60 to $40
Some lights to look at within your price range assuming you want to stay with AA batteries:
Fenix L1P - 1AA makes this light small and pocketable. Similar in light output as the 3 watt Nexxtech/Nuwai in my price sample. 4sevens and litemania sell it in the dealers forum. JSB and Emillion sell it over the net.
https://www.jsburlys.com/shop/index.php?cPath=33&osCsid=e0b75bd8625dd24e6ed63559f147a2c9
http://emilionworkshop.com:3072/osc...d=309&osCsid=8fb2254be749ce10ef66809ed9493c4f
Looks like the less expensive L1 will soon be available again
http://www.lighthound.com/sales/fenix_l1.php
If you really need the light of a true 3 watt try the Electrolumens Blaster Jr. It is big, the size of a 2D torch.
http://elektrolumens.com/
