carrot
What single cell light(s) output useful light the longest? (Useful, as in blackout situations.)
Actually the 300+ hr runtime is on a U42, and at 0.3 lumens -- 4 levels brighter than the lowest 0.08 lumens.John N said:The HDS EDC lights are supposed to get 300+ hrs on their least efficent light on it's lowest setting (1x123A). My understanding is the brighter models and XR models should do even better - with the U85 doing best...
+1trauts14 said:Lightwave Pro4000. I have an older version and during winter storms here in NC I have had mine on straight for a few days. I think its life is about 900ish hours.
joema said:Actually the 300+ hr runtime is on a U42, and at 0.3 lumens -- 4 levels brighter than the lowest 0.08 lumens.
AS you said, the U60XR should go longer at 0.3 lumens (the 300 hr setting), and the U85 longer still. That info used to be on the HDS web site, but they removed it as they're updating it with new data from more extensive tests.
A U85 on the lowest setting of 0.08 lumens would probably run over 1000 hrs, and incredible as it sounds, that's conservative.
Assuming drive current is linear, 0.08 lumens should take 3.75 times less drive current than 0.3 lumens, which equates to 1125 hrs, and that's for a U42 without the efficiency improvements of the U60 or U85!!
Is there any other light that runs over 1000 hrs on one battery?
Actually the U42 should run for 1000hrs on 0.08 lumens -- it runs for 300 hrs on the brighter 0.3 lumen setting. The U60, U60XR and U85 should run even longerJohn N said:I have no idea if 1000hrs (for U85) is correct, but if one were to consider rechargables, the soon to be available 18650 battery and battery tube, should net you over 4X runtime vs a 1x123 cell configuration. That would be impressive even if the U85 only got 300 hrs...
joema said:Actually the U42 should run for 1000hrs on 0.08 lumens -- it runs for 300 hrs on the brighter 0.3 lumen setting. The U60, U60XR and U85 should run even longer
In theory a U85 using an 18650 at 0.3 lumens could run for 4000 hr (about six months, continuous). I suppose at 0.08 lumens it would run a couple of years, continuously. That makes an Eternalight look like a 15 min. Orb Raw. Incredible.
