FourSevens
Results 1 to 7 of 7
Thread: Emmitter vs star
    Dec 2005
    Portsmouth. VA
    Default Emmitter vs star
    Just looked at Lumiled's web sight, notice they had the star and the emmiter at about the same price. Would somebody please edumacate as to the difference between the two?
    Thanks
    Will
    Default Re: Emmitter vs star
    An emitter is just the LED a star is the LED mounted on a heatsink and a PCB.
    Dec 2005
    Portsmouth. VA
    Ahh, that is what I thougt, and that little heatsink is all that is required?
    Flashaholic falconz's Avatar
    Jan 2005
    Singapore
    in my opinion no, cos they are usually encased inside the flashlight bezel so heat dissipation is definitely not enough....better have it attached to a bigger heat sink by a good heat transfer epoxy.
    At the end of the tunnel of Light I saw........an empty wallet....
    Flashaholic* cratz2's Avatar
    Apr 2003
    Central IN
    If you are wanting to mod an existing light, then you probably need one or the other (either the star or the bare emitter). Of course, the emitter is easy enough to remove and then reattach to the star if needed for future projects.
    "That's what makes SF so badass... we've got the best flashlights."
    Flashaholic* offroadcmpr's Avatar
    Feb 2005
    CA
    similar thread http://candlepowerforums.com/vb/showthread.php?t=98857 I asked about it a little bit before.
    *Flashaholic* IsaacHayes's Avatar
    Jan 2003
    Missouri
    The star makes it easier to handle as it has solder pads to add wire without extra solder, and screws can be used to hold it down onto a heatsink. The emitter is more fragile but there's more mounting flexibility because it's small and one less thermal path to the main heatsink.
