CajunBabe said:
My questions are, what 42" plasma do you have (brand / model) and what are your likes and dislikes? What features made you choose the particular one?
LCDs are "cold" technology while plasma's are "hot" technology. I wouldn't put a plasma TV inside a closed entertainment center for ventilation reasons.
If you're not comfortable with researching equipment to find a perfect match with a plasma "monitor," I would look at plasmas that offer internal HD tuners and SD tuners, preferably with a cable card (all you need is a card from the cable company rather than a separate box that uses a separate remote, etc.). However, you're going to pay more for all of this. Panasonic makes some highly recommended plasmas complete with cards and tuners. However, they are high $$ units as well. Maxent 42X3 model was an excellent unit at Costco, but they do not stock it anymore (monitor only model). You might look at some of the Vizio products if you want to save money.
ED (enhanced definition - 480p) might also be a better choice if you want to save money. 480p (progressive) sources are much more common such as progressive DVD players. There are currently macroblocking problems with the MPEG-2 compression standard that show up on higher definition sources (720p and up). Standard definition (SD) television signals look better at 480p than 720p or 1080i.
State of the art (SOTA) - 1080p (progressive) is the only true high definition TV. 1080i (interlaced) is "near HD". Westinghouse and Sony make a few 1080p capable units and more will come out in the next year. Talk of blu-ray DVDs (1080p) using MPEG-4 compression is also coming in the next year.
Maybe this if obvious, but the numbers refer to 'lines of resolution'. So, a 480i or 480p source provides 480 lines of resolution, etc. A progressive source provides even and odd lines of resolution with each frame. An "i" or interlaced source alternates drawing odd and even lines every other frame (generally does not look as sharp as a progressive picture).
Will you use the set more for SD watching, DVD watching, cable HD watching, over the air (OTA) HD watching (you have about 17 local over the air HD channels) or something else?
