John at AdvancedMart sent this chromed brass 1AAA 0.5watt (LED-050AAA) light (thanks John!) - along with my replacement 0.5w 1AA - AdvancedMart LED-005S
Size comparison -
It's about the size of the Dorcy 1AAA - slim body with wider head. But it feels heavy - being chromed brass. The switch is on the side of the body toward the front - it works like a reverse clicky.
Heads -
The 0.5watt LED looks like the same as the 1AA version (0.5w 1AA - AdvancedMart LED-005S) its die size looks smaller than the ones in the 0.5watt Nuwais and River Rocks.
vs. Nuwai 0.5w 1AAA (TM-310H)
Pretty similar brightness and beam characteristics - except the AdvancedMart 0.5w 1AAA has a much nicer (less blue) tint than the Nuwai.
vs. Dorcy 1AAA
The 0.5watt 1AAA as expected is noticably brighter than the classic (1st gen) Dorcy 1AAA that I EDC.
Even though the output performance of this light is quite obviously a lot better than the Dorcy 1AAA and the size shape is similar - I don't think this light will take over as my EDC as yet - for form factor reasons - which I'll probably discuss in another thread, later.
vs. 0.5w 1AA - AdvancedMart LED-005S
I vacillate in my preference between these two flashlights' beams. The AAA version seems just a slightly better tint, and I kind of quite like the way the hotspot is less distinct fading toward the side-spill/corona. But I also like the noticably wider hotspot of the AA version but not quite as taken with its more abrupt change to its side-spill.
Looking at the heads shot more carefully one can just make out the difference in the reflectors which are responsible for the beam differences - even though the lens and head diameters are the same. The AAA version seems to reflect more like a donut/ring of yellow phosphor - whereas the AA version seems to fill the reflector. I would have speculated the AA version's reflector is actually better designed...... but I'm no expert on this.
In the review of the 0.5w 1AA - AdvancedMart LED-005S there is quite a bit of discussion about potential conductivity problems due to anodized threads.
On this AAA version there is no such problem as the body material is chromed brass and the threads and actually the entire body is electrically conductive. This means that the body outer is conductive, I don't think this makes any difference in normal use - but I don't know if anyone can think of objections of having a flashlight body that is fully conductive to the outside?
Size comparison -
Heads -
vs. Dorcy 1AAA
