jezzyp
All I did was put some of lighthounds nyogel on the screw threads and now it won't light.
Heeeeeeeeeeeeelp!
Heeeeeeeeeeeeelp!
In addition to what BlackDecker suggested, have you checked to see if the plastic switch-retaining ring (edit: it's a metal ring) is screwed all the way in? Some of them are shipped from the factory with the ring a little loose (including mine) and if the ring is loose you can have switching problems. Tighten up the ring, and the problem goes away.jezzyp said:All I did was put some of lighthounds nyogel on the screw threads and now it won't light.
Heeeeeeeeeeeeelp!
