The LED has made possible small pocketable flashlights with usable amount of light.
I find that I am more and more leaning toward single celled lights - just for the sheer convenience of portability - to the point of pocketability in pants/slacks pockets........
Sizes -
Shown here are some of my favorite single cell lights with a typical pocket knife the Victorinox Swiss Army Knife as a reference.
These lights range from single 5mm LED brightness to the level that will rival a 3D Maglite.
Most popular pocket folding knives usually fall into the range of 3.25"-3.75" - the SAK is 3.5" (91mm) right in the middle of the pack. Of course YMMV - depending on the size of one's pockets and how much one is willing to tolerate. A 3.5" pocket knife/flashlight may be too big or too small for others and I accept that - I am merely thinking out loud on my rationalizing of form-factor/size/ergonomics.
Looking at the photo above would suggest that any of those flashlights would fit nicely in pants pocket - but that's kind of one dimensional (OK two )
Because it does not show the thickness of the pocket knife -
A two layered SAK is about the right thickness for comfortable pocket carry - this is not a hard and fast rule - I do realize that there are many (including me occassionally) who can and do carry thicker like 3 or even 4 layers - but two layers on a SAK is what I consider an easy and comfortable carry.
Now looking at the photo with the SAK sideways on one can see that many flashlights now don't look as compact.
Obviously most flashlights are cylindrical and it is going to be hard to equate these to a pocket knife - so let's put this aside for a moment -
other than accept that for me a light should probably fall into the length range of about 3.25"-3.75" - with 3.5" being the one I'm most used to (again YMMV)
Let's take another look -
I've long been enthusiastic for lights that use a single common AA battery - my first LED light other than a Photon was from reading CPF and purchasing a CMG Ultra-G from CountyComm - 1x 5mm LED 1xAA - I liked it so much that I bought a second one.....
Eventually I contracted full Flashaholicsm and among my purchases was the cheapo Dorcy 1AAA . Initially I didn't think too much about the Dorcy 1AAA, other than it was a bargain - since it ran on a single AAA battery which cost as much as an AA - and had about 1/2 the capacity - so economically it costs twice as much to run than an AA version.
The Dorcy 1AAA was also quite a bit larger than a single AAA battery - unlike the small and elegant ArcAAA that was everyone's favorite at the time.
But I started to carry it mainly because of the convenience of the momentary ON tail-switch.
It then became my EDC (EveryDay Carry) displacing my then favorite Ultra-G.
What gives?
The Dorcy is bigger than it needs to be - runs on a battery that's twice as expensive as the AA - it's not that well made and there were quite a lot of initial problems with tail-switches and so on.........
Well I kind of partially figured this out fairly quickly.
It's not just about how small the light can be -
but how well it "fits" - hence my use of form-factor and even "ergonomics"
The Dorcy 1AAA length is about ideal just a bit shorter than 3.5"
The head is wider at about 18mm - but its body is only about 14mm wide/diameter and the tailcap is a bit wider at about 15.5mm. So it fits in my pants pocket really easily and comfortably.
The Dorcy 1AAA also gave me the right amount of light for most of my EDC usage - I even found that it worked well outdoors in the countryside - Dorcy 1AAA Outdoors - this may well be a case of some light is better than none - but it went a little beyond that (please read the thread).
The Dorcy 1AAA fitted well in my hand for use, the momentary on tailswitch worked well and the rubber inserts fell in the right places for me in use.
I also found the Dorcy 1AAA made a nice "mouth-light" because of its size and rubber inserts.
Nevertheless like a truly afflicted flashaholic I was alway on the lookout for the ideal EDC pocket flashlight - especially in a single AA.
With the arrival of the Fenix L1 (P) and even the 0.5w 1AA - AdvancedMart LED-005S - one would have thought I may have found it.......
BUT -
Let's look at the lights with their respective batteries.
Again notice most of them are substantially larger than their battery.
This obviusly stands to reason since one has to allow for the lens and reflector, the LED and driving circuit and the switch..........
So with the two cited (otherwise fabulous) single AA lights I finally got it through my head an ideal EDC pocket light is probably not possible for me on a single AA - even though I love single AA lights!
The AA battery measures approx 14mm diameter - so even with the slimmest of bodies it is unlikely to fall much below about 17mm diameter - the 0.5w 1AA - AdvancedMart LED-005S is already 18mm in diameter and it feels too bulky for an ideal pocket light - yes, of course I can pocket it - but it is not as comfortable as my Dorcy 1AAA either in the pocket or in use......
The Fenix L1 (P) is about 20mm in diameter and feels quite a bit heavier - so even though it is a fabulous light by any reckoning - it fails as my EDC pocket light.......
So that will eliminate the 1x CR123A lights since the diameter of the CR123 is already approx 17mm so we are probably unlikely to see any lights that will be less than about 20mm in diameter - and both lights shown in my photo exceed 25mm!
OK that leaves me with AAA lights -
The Nuwai 0.5w 1AAA (TM-310H) is actually very compact gives good output and reasonably long runtime and the momentary on tailswitch works better than the Dorcy. Its diameter measurements are similar to the Dorcy. However it is a bit too short from ideal at approx 3". So I had to learn to hold the light further up the body (actually using the pocket clip as a locator to put the inside edge of my little finger against) so that my little finger did not block some of the light. But it is still in contention - as I am EDC'ing the thing at home as a trial.
The recent 1AAA 0.5w AdvancedMart LED-050AAA looks good as it is about the same size and shape as the Dorcy 1AAA - quite a bit heavier feeling - better made, better output and beam - so what's not to like?
Unfortunately it's the switch position - it's in the "conventional" position on the side of the body tube just by the head, well positioned to avoid accidental switch on - but I've gotten used to tail operated switches for pocket sized lights and it just cannot displace the Dorcy 1AAA for this single major ergonomic reason and it falls short (pun intended) than the shorter than ideal Nuwai 0.5w 1AAA (TM-310H) (which I like enough that I've ordered a couple more from LED-experimenter's current Sale)
I hope some of all this makes some sense and it doesn't just sound like a long(-winded) ramble.
I am hopeful this thread will spark/initiate some discussion on the question of form-factor, size and ergonomics
Sizes -
What gives?
BUT -
