woodfluter
- Joined
- Dec 14, 2005
- Messages
- 142
Was not impressed with what I'd read about X5 output, but couldn't resist playing with them at Target. Well, I checked about 20 of those with white LEDs (you know the little cutout with "Try It!" on the bottom?) and found something surprising. OK, it's projecting through the plastic packaging, and I had to wiggle that a bit to be really for certain yep youbetcha sure, but their output seemed to fall into two groups, one significantly brighter than the other.
Of the brighter ones, there seemed to be some small differences in focus of the individual LEDs, and I finally narrowed it down to the three best and took one of those. It sure puts out more than I expected - slightly bluish but not bad and perfectly even flood of light. (Way more even than a blue one a friend has.)
I used my Gossen F photographic meter with incident attachment to make some approximate lux readings at one meter using pretty fresh batteries, and the *comparative* results differ quite a bit from Quickbeam's (now-dated?) measurements:
X5 lux vs Inova T2: 50% (Quickbeam got 12%)
X5 lux vs new Surefire L1: 20% (Quickbeam got 6%)
So, uh, what's going on here? Same model number and labeling on the packaging. If they switched to something new and improved you'd think they would not do so quietly...
