PEU
I started this build from scratch yesterday, I found a piece of acrylic tube and the modder inside did the rest
The unit is powered by a MC33063 in illpill configuration with a huge inductor, the emitter is a TWOJ star dremeled to 20mm diameter. Then the whole circuit is sandwiched (a huge one)
The top aluminium part is held by presure, and the bottom is threaded, so you guessed right, is a twisty, the unit works with CR123 batts.
The reflector is a cut down IMS20 and the lens is from a m@gAA, because I don't have a proper size UCL.
Looks was my main concern, heat path is awful, efficiency is not up to current standards, but it works and is nice
Here are a few pics:
I will add some glowpowder to the inside of the tube or to the sammie, not sure yet.
Hope you all like it.
Pablo
Pablo
