Where To Buy DownBoy & Luxeon LEDs?
nemul
Georgia
InfiniteReality said:
dang they have LOTS of choices in LEDs! Any recommendations?
what kind of light do you want? big, small, flood, spot, etc....
nemul
Georgia
I would like a spot light. Thanks!!
go with a LuxIII and Maglite C or D cell. the large reflector can focus the LuxIII tight....
InfiniteReality
Lake Charles, Louisiana
I'm not planning on using a reflector, planning on using a set of 2 or 4 (depending on $$$) of them per fog light on my car. Do any Luxeons spot more than others?
Thanks!
- Del
CLHC
PNW|WA|USA
Now that is an interesting concept for what you'll be using it for—and to think it's all from The Sandwich Shoppe. . .Hope you find what you're looking for and Enjoy!
InfiniteReality
Yep, something different. Not expecting any performance gains by using Luxeon's for Fogs, just pure visual. I just ordered HIDs for the car and the LEDs will match them VERY nicely! Way better than investing twice in HIDs for the fogs. =)
CLHC
PNW|WA|USA
Sure would like to know how your modded LED fog lights work on your hot-rod when you've gone an done did it Del!
InfiniteReality
Not sure if I'll mod existing housings for them or will just use a board. The lenses are broke on the existing ones, so I don't really want to use it. BUT if I did I'd have use of a reflector.
I will definitely post afterwards! :)
Can you recommend a Luxeon LED for this use?
CLHC
PNW|WA|USA
Sorry for I'm still new myself and would'nt even know where to begin on that one. Someone will chime in with a recommendation soon enough.
IsaacHayes
Missouri
perhaps 1 luxV per fog light. With the largest optic or reflector that will fit. I think that perhaps www.elektrolumens.com 30mm optics would be cool. The luxV would put out a lot of light from one led. Just make sure you have good heatsinking.
InfiniteReality
What do those run? I can wire up typicall 5mm LEDs like a pro, but not familiar with these. Are they the same to wire up? I plan on using a downboy to control the power to them. I'm also looking to spend about $30 per fog, but not sure how much a 5w would run.
Morelite
Central PA
you will need something in the U-bin range and will need to wire 2 of them in series, if you do it that way you will not need a DownBoy or any converter. Don't forget that a cars charging system is based on 14 volts and not 12.
Two U-bins in series will take upto 14.76 volts nicely.
InfiniteReality
I still want to use a downboy though to regulate the voltage. LEDs I have on the car now (like my front illuminated plate) pulse just a little while the car's running due to the voltage moving around a little. It sucks, but it'll kill two birds with one stone. :)
