I have upgraded my Fenix L1P (R-bin LuxI) to an S-bin LuxI (got it a few weeks ago from LEDsupply on this forum) today, and I'm very satisfied by the final result I have 2 Fenix L1P's from the same batch (so everything is the same) and I've swapped the LED of 1 of them to the S-bin. Afterwards I compared the lux readings (both with fresh batteries from the same package). Lux readings of the S-bin were about 42% higher at the same distance! Global light output also increased significantly, as you can see on the pictures (on every picture the stock L1P is left and the S-bin L1P on the right) :
- Notice the brighter hotspot and the brighter sidespill on the modified L1P.
- Decreased shutter time which makes the better throw on the S-bin visible.
- Shutter time decreased again
- Picture on a wall at about 2-3 meters.
I was surprised by the huge improvement the S-bin was against the R-bin. Typical output for the R-bin is rated at 45,75 lumen versus 59,45 lumen for the S-bin (calculation based on the average from each range as seen on http://home.comcast.net/~theledguy/bin_codes/ ). This is a typical brightness increase of 30%, while I measured an increase of 42%. This makes me think the R-bin must have been less than typical lumens, and the S-bin more than typical lumens. Great
My Fenix L1P S-bin is my new EDC
Thank you for watching!
Erasmus.
Erasmus.
