Are some of the numbers displayed by the La Crosse charger computed rather than measured?
During charge, if I put the cells in and then plug in the charger, then the mAh readings for all the cell seem to always increment in lockstep, despite the current readings varying somewhat. Is that what other people observe?
(During discharge, this isn't the case - the mAh readings for different cells are close but often I have seen one increment before or after the others.)
I had a problem and got a replacement charger from La Crosse, and it was defective - the first slot didn't charge. The battery voltage never increased in that slot, and I measured almost zero current with an ammeter.
But the mAh reading for that slot kept counting up, just the same as all the others.
So I'm wondering if that number represents a real measurement, or if it's just computed based on the programmed charge current.
I'm hoping to hear that I'm mistaken and the mAh displayed during charge is real.
By the way, in the other slots my digital and analog ammeters didn't show anything near the charging current. Is the charger putting out pulses or some other fancy waveform?
