fire-stick
I guess I could use the energizer 2500's I have but I don't know if they can handle the BID D bulb? Would I be better off getting some CBP 1650's?
SilverFox said:Hello Fire-Stick,
Both cells will work. The light will be brighter with the CBP 1650 cells but run time will be less than if you use the Energizer 2500 cells.
Tom
modamag said:ROP only pulls 2.0A so it's not even 1C yet. At that rate CBP1650 have ~0.4-0.5V advantage over Energizer 2500 or Titanium 2600.
[\QUOTE]
I guess you were referring to the ROP LOLA. What would be the difference on the HOLA which draws 4 amps?
modamag said:lexina: I must be getting rusty cause I have no idea what a HOLA is. If you could provide the spec/voltage/cells/current I can do a theoretical guestimation.
Also, wouldn't both of these lamps draw even more current at 7.2 volts? :thinking:lexina said:Sorry, I know the terms HOLA (high output lamp assembly) and LOLA are more commonly used to describe the high and low output lamp assemblies of Surefire products (for eg P60 vs P61). The ROP lamps also come in a set of 2 - the high output lamp is rated at 6V, 4A, 24W and the low output lamp is rated at 6V, 1.8A, 10.8W.
modamag said:Ah, that's what HOLA means. Well I guess I jump in too earlier with the ROP deal cause I have a LOLA (kinda like the lolita). Thanx for pointing that out lexina, maybe I'll get the HOLA set and see if I can appreciate the ROP a little bit more.
45/70, they don't really draw that much more current. On my Mastech 30V/30A power supply it's only sucking 1.9A - 2.0A. It was under constant voltage regulation and wide open for current draw.
Here's the estimate for the HOLA with 6xAA NiMh.
CBP1650 with 4A draw @ 0.5Ah is ~1.21V
Energizer 2500 with 4A draw @ 0.5Ah is ~1.14V
CBP1650 would be ~ 23% more intense (7% brighter) than Energizer 2500
Intensity Delta = [1.21/1.14]^3.5
Runtime will increase by 31% with Energizer 2500 (2.329Wh) vs CBP1650(1.779Wh).
* Note linear interpolation of power rating
adirondackdestroyer said:If anyone can suggest a nice charger that would charge all 6 of the 1650 batteries at one time, that would be great!
cmacclel said:Using a set of Sanyo 2500's which I think Energizer and Duracell 2500's are just re-branded Sanyo's anyway pulled 3.8 amps on a full charge using the high output lamp.
Ma
