deranged_coder
Just curious what everyone does as far as cleaning and maintaining their lights. I do not have a particular set schedule for doing cleaning and maintenance on my lights but what I usually do when I decide it is time to clean them is the following:
I do not use my lights particularly hard so this cleaning routine works fine for me. So, what do you do to clean your lights?
- Disassemble the light(s) and wipe down all contacts and threads with a paper towel.
- Use DeoxIt on all the electrical contacts. Let it soak for a couple of minutes, shake off the excess, then let it sit for a few minutes more.
- Use ProGold on all the electrical contacts. Let it soak for a couple of minutes, shake off the excess, then let it sit for a few minutes more.
- Use silicone grease on all the threads and O-rings.
- Use a Windex wipe on the lens after first blowing off loose dust.
- Re-assemble light(s). Switch on and off several times to make sure I did not break anything while I was mucking around with things.
