Klarus
Page 1 of 3 123 LastLast
Results 1 to 30 of 66
Thread: got some Sylvania Dot-Its really impressed
    Flashaholic steve_vance's Avatar
    Feb 2003
    Bucks County,Penna
    Thumbs up got some Sylvania Dot-Its really impressed
    there were some previous threads about the new LED module from Sylvania, the Dot-It.
    http://www.sylvania.com/ConsumerProd...s/Dotitlights/
    I received a couple dozen yesterday (donation for Cityteam, the group working in Mississippi THANK YOU SYLVANIA); I was expecting plastic cases and shoddy workmanship, what I got was a solid machined aluminum case and really great workmanship: THESE THINGS ARE BEAUTIFULLY BUILT.
    The clickie switch is good quality: has a very positive feel. They use 3 AAA cells and advertise about 100 hours of runtime- that's probably using the same "usable light" standard that some of the LED flashlight makers use. I'd give it more like 25 hours of "good " light. The LEDS are all of unoiforn brightness and pure white: I'd estimate that they are the 8000-10000 mcd 5mm that most flashlight makers use.
    The only concern I have is that the battery compartment (accessed thru the back) must be unscrewed to access the batteries. That could be a pain: they are literally VERY TINY Phillips screws and cpould be lost easily. And if you stick it onto a surface, using the supplied sticky backing, you might have trouble changing the batteries. As someone else suggested in a previous post, may be better to attach velcro.
    All in all, though, I'm impressed with the quality, fit, finish and performance of this unit. They did a good job with this one. IMO it's a product design that will be suitable for a number of uses: closet light, camping, tent light, dome light for car or truck, IMO it would be a great item to put in a household disaster kit (it's shaped like a hockey puck- 2.625" diameter X .625" thick-- so the user could put it on a table and face it at the ceiling. The 3 LEDs would be bright enough to light a whole room)
    BRIGHT, TOO!!!
    They'll be sold at Walmart for about ten bucks each, but not every Walmart will have them. There's a list on the Sylvania website.
    There will come a time when incandescent bulbs can only be found in a museum exhibit. LEDs !!!
    Flashaholic bruner's Avatar
    Oct 2005
    North Central Pennsylvania
    Default Re: got some Sylvania Dot-Its really impressed
    Hi Steve,
    I just learned about these a few days ago, looking in a magaize, waiting to get a haircut. Glad to hear thay are well-made.
    I looked for them at my Walmart, but couldn't find them yet.
    Can you post any pictures? Maybe take one apart and snap a few shots?
    Thanks,
    Dan
    'Tis the gift to be simple.
    I have one from Wal-Mart, but it has a plastic body cool little light.
    Flashaholic* Christoph's Avatar
    Aug 2002
    Hagerstown,Md
    They just started an add campain on tv recently.I used a piece of flat rubber magnet on the back and hung on back of front door(insert metal surface here).
    at 100 hours run time intermitant use you may never change the batteries.It should have been turn and pull bayonet type cover they could have saved three screws and the time it took to install them.
    Chris
    *Retired* NewBie's Avatar
    Feb 2004
    Oregon- United States of America
    I saw these in the local WalMart this week, hanging on one of those impulse buy strips they seem to randomly locate.
    Nov 2003
    NTX
    I secretly suspect I am getting some dot-it's for Christmas in my stocking...!
    I did email Sylvania in a pointless attempt to learn what bin led's they use. No joy--they won't say other than it's 'proprietary' info.
    Spark headlamp,712-L headlamp,D25c mini,Fenix PD35, E+Lite, Zipka, Novatac 85T.
    *Flashaholic* greenLED's Avatar
    Mar 2004
    La Tiquicia
    Cheap Indium-Puck knock-offs, IMO.
    Flashaholic* Phaserburn's Avatar
    Mar 2003
    Connecticut, USA
    Quote Originally Posted by greenLED
    Nah, don't think so. I got a couple myself. No one has made led lights that are for under cabinets, etc before. These lights are simple, durable and of good quality. I have on inside a closet and another inside a tall floor cabinet. As I will only use them for a minute or so at most at a time, the batteries will last many years.
    The Phaser: A nice EDC with great throw; heat and runtime can be issues.
    Best Diffusion Film!
    Feb 2003
    Bucks County,Penna
    no offense, Greenled, but if you had one in your hand you wouldn't say that
    I own bazillions of super-high-quality LED lights and I stand by my remarks. Have a great holiday!
    *Retired* The_LED_Museum's Avatar
    Aug 2000
    Federal Way WA. USA
    I've seen the commercial on television at least two times; I did not find them at Wallgreens or Safeway - there's no Wall*Mart I can get to, so I cannot check them.
    Mar 2002
    CT
    Amazon.com sells them - $10 each.
    I bought a couple - decent output, seem well made - it's basically a small tap-light w/ LEDs installed.
    Jul 2005
    illuminationGear
    Quote Originally Posted by DaveG
    are there two versions floating around -
    plastic body vs aluminum body?
    the reality of life... 50% +/- of it will be in darkness (unless you have a light!) dba
    (also EagTac-USA)
    Quote Originally Posted by lebox97
    After reading this I gave mine the scratch test with a screwdriver, its looks like it is aluminum! The paint job is so glossy it had me fooled. Steve was right on about this one. Iam more impressed with mine now, not bad for under $10.
    Feb 2004
    I'm looking at one right now, it has a plastic body, with a thin aluminum over-shell, which comes in different colors.
    These don't even come close to the indium, in almost all aspects.
    Thats like comparing a Surefire to a flashlight you buy at the dollar store.
    Unfortunately, they make crappy tap-it lights that you see on TV. Tap-It lights light up an area, these shoot a narrow beam. In several places where I tried the Dot-It, the narrow beam was shot onto something dark, which for the most part absorbed the light. If you mount it sideways, such that it projects onto another white wall, it helps alot.
    Though fixing these, like you do with the RiverRock lantern, adding various diffusion films, or scratch finishes, would help alot.
    Jan 2005
    Indiana
    Is there anyreason to NOT use these inside a gunsafe?
    Will alkaline batteries vent anything that will cause corrosion?
    Would Lithium batteries be a better ,or worse, choice?
    I wasn't able to find the Dot-Its at Wal-Mart here earlier in the week.
    Flashaholic* Flash_Gordon's Avatar
    Apr 2005
    NC USA
    Post Re: got some Sylvania Dot-Its really impressed
    Quote Originally Posted by db
    If you can find a good mounting place, these should be excellent in a gun safe. Neither battery chemistry should present any problems as long as you keep good fresh dated cells in it. I would go for the lithiums simply because of their longer shelf life and you really have a long term use situation in your safe.
    Unknown yet whether these things are happy with the higher voltage of lithiums.
    Mark
    Flashaholic* DUQ's Avatar
    Jun 2005
    Ottawa, Ontario, Canada
    I had know idea they were made of aluminum. I'll grab one when I see them next.
    LED's impress but Incans satisfy
    Oct 2005
    DUQ,
    To quote NewBie "I'm looking at one right now, it has a plastic body, with a thin aluminum over-shell, which comes in different colors".
    Unfortunately, not all aluminum.
    Dan
    Aug 2001
    VA
    I saw them in the auto section of walmart not in the flashlight section.
    Light is the activity of what is transparent - Aristotle
    Feb 2004
    Well, bad news.
    The DOT-iT is cheap inside, just a resistor, and three LEDs in parallel. Putting LEDs directly in parallel is not a very good idea, as the current is not matched, since LEDs never have the same Vf.
    Of course, what do you expect for 9.95? One resistor under a penny, three LEDs costing 0.25 ea, a 0.10 switch, and at the most, 0.10 in the circuit board. Electronics and LEDs look to cost them under 1 dollar, and at their volumes, it is probably less.
    As such, the unit has basically an unregulated output.
    The unit contains a low cost vacuum metalized piece of plastic that also functions as the reflector.
    But, I measured the current draw, and it is 5.83mA. Since the LEDs are in parallel, this works out to 1.94mA per LED. In this condition, you don't have to worry too much about Vf matching.
    Running the LEDs at 1.94mA means they are running in a very efficient portion of their range, and the runtime should be very nice, as well as give the LEDs a very long life.
    FYI, measurements were made with fresh cells, reading 1.565V each, and the unit contains 3.
    Pictures:
    Aug 2002
    Hagerstown,Md
    The switch has a momemtary on function can you tell who makes it ?
    C
    Chris
    Nov 2003
    NTX
    I got a set of 3 for Christmas today! I rather like them. I think they will do well inside the safe with either a velcro mount or magnet. Probably a rare earth magnet will work best, glued in place. They also look useful for power outages.
    Oct 2005
    Santa Rosa, CA
    Quote Originally Posted by The_LED_Museum
    <snip>
    <snip>
    Well then... in a way, you're a very lucky man.
    Ken
    *Flashaholic*
    Apr 2004
    Lost In Space
    cool, so pull the leds and put in 4xdie 5mm parellel leds, dump the resister to say 22-33ohm, and you got a mod in a few minutes.
    then all it needs is a 2 level switch :-)
    as far as closets go, even the push lights did not do the job for any of my closets, "safe" light sounds about right.
    i had to stick in more than 13 5mm leds to get a push light to be a usefull closet light.
    so who will have it modded first?
    Nov 2005
    York, Pa.
    I stopped at Walmart today since my store was listed on Sylvania site. The guy knew what I was talking about and he said they sold out. It was a special purchase. Not sure where I'm going to get them now.
    good idea! sounds like an good price to me and i will test one for sure.
    Flashaholic* Omega Man's Avatar
    Nov 2005
    East Coast
    Also got slack jaws and blank stares from the local Walmart employees about this light. They tried to shuffle me around to other departments, and after looking in 3, I gave up.
    RIP Don and Mike Show. Long Live The Mike O'Meara Show!
    Aug 2000
    Federal Way WA. USA
    I tried Larrys Market, Wallgreens, and Safeway...no joy.
    There's no Wall*Mart anywhere I can get to, so I can't check that store.
    If anybody can mail me one of these, I'll gladly reimburse you for the light *and* the postage.
    My address is:
    Craig Johnson
    The LED Museum
    745 N. 104th St.
    Seattle WA. 98133-9211
    This address is published all over the internet, so I do not mind posting it here.
    Nov 2005
    York, Pa.
    I found them at Advance Auto Parts today. They only had 3 left in stock. I picked one up. I like the concept but its not real bright. I will have to replace the LEDs when I get a chance. The packaging says you can apply and reapply to surfaces. I wonder how times it will before it looses its sticky.
    Steve
    Flashaholic* Pydpiper's Avatar
    Jan 2005
    Brantford/Woodstock
    My address is:
    Craig Johnson
    The LED Museum
    745 N. 104th St.
    Craig, if you still need one, I will go find one for you. Pm me.
    Just one more light and my collection is complete! Ok, maybe two..
