winny
I know it's Christmas, at least here it is (Why is it that you guys over there celibrate Christmas day and we celibrate Christmas eve anyway?), but that doesn't stop me.
I hope that someone hasen't taken the name MonsterMag yet...
This project started in April this year when I got a Philips Masterline ES lamp from a guy I know at Philips. I looked it up and found no other MR16 lamp that was so efficient with so narrow beam. Because of its rated AC-life of 5000 hours, I immediately thought - OVERDRIVE TO THE MAX! Out of the 5000 hours I only plan to be able to use 100 of them, which would mean a bulb-cost of about 22 cents per hour.
Next on the agenda was batteries. Using a 3D host, I could only get 14.4 volt using AA NiMHs. 2/3AA could have done the trick but I opted for 12 Li-Ion AAs. The resons for not using the 14.4 volt solution where two:
1. Boost converters are not as efficient as PWM.
2. There was no room for the coil needed, especially as I wanted to be able to run at 10+ ampere.
The biggest and hardest part was the actual PWM circuit. As I'm an electrical engineering student and we don't learn anything useful in school, I decided to put the rib high in order to actually learn something.
Therefore I planed for the following features:
* soft start, in order not to instaflash my bulb
* temperature sensing, just about every component is running on or well above specifications so I figured that some safety is needed.
* 0 uA stand-by load, just because.
* software breaker, because there are no 10+ ampere breakers with negligible resistance in my price range.
* LED indication of battery status, temperature and so on.
* 95+% efficiency, there are no other way using no cooling.
* must be smaller than a D battery in diameter.
All of this was achieved thanks to many hours of work and a buckload of help from my friend Alexander. Thanks Alex!
The data:
Host: Mag 3D, black
Lamp: Philips Masterline ES, 12 V, 45 W, 8 deg, 5000 hour
Batteries: Batteryspace.com's Li-ion 14500, 750 mAh
Battery adapter: modified modamag 12 AA -> 3D
Switch: Bulgin MPI002, LED illuminated
Circuitry: Own design, providing temperature sensing, soft start, full regulation provided that Uin => Uout, LED indication, 95+% efficient
The beamshots:
Please note, currently the MonsterMag is running at 15 volt instead of 16.2 as intended. The data is based on 16.2 volt. The stock Mag had AA batteries, measuring 1.6 volt each before the test but one might argue that AA cells sag under from the 1 ampere load. Nevertheless...
The setup.
Supersize picture
Stock mag. ISO 50, 10 seconds, F 2.83.
Supersize picture
MonsterMag 1 at 15 volt. ISO 50, 10 seconds, F 2.83.
Supersize picture
The difference.
Superize picture
The data:
Host: Mag 3D, black
The beamshots:
The setup.
Supersize picture
Supersize picture
Supersize picture
The difference.
Superize picture
