Paul_in_Maryland said:
One puzzle, though: When you order the
BOG 3W, you must specify if you need the G2 version. When you order the
G&P 3W from Lighthound, you don't. What gives?
Hi Paul:wave: The difference is a little removable ring that helps with the electrical contact in the G2.
lighthound.com probably just includes them with every one, the actual module is the same.
My latest 3W from BOG is a tad whiter than an earlier version though, don't know if that is individual or across the board.
My switchable 1/3W from Emillion is a little whiter again, but in a Nitrolon light on 2 R123's it gets a little too hot, I use a single Li-Ion on that one now.
All of these get beaten in brightness/whiteness by the Streamlight 4AA Propoly Luxeon, which is an (overdriven) 1Watt (!) - a whole clunky flashlight for less than the price of a drop-in......
In another post someone mentions that the
LED Scorpion is similar to this, so if it's just the output and not the flashlight lego possibilities you want, there's two ways of saving a little bit....
