HDS Systems
Results 1 to 24 of 24
Thread: Ideal all rounder led? Need some advice...
    Feb 2005
    Australia
    Default Ideal all rounder led? Need some advice...
    I am looking to purchase a led light for my father as he recently bought a house in the bush. What I'm looking for is a reliable flashlight that can be used both for bushwalking and investigating strange noises etc. so two stages of light would be a good idea. Also the light must have a reasonable amount of throw so it can be used to search the property at night. Not looking to break the bank but I need something he can rely on so I will pay for quality. I own a surefire L2 which is great but the light for my father needs more throw for it to be useful as his sole flashlight. Any ideas? cheers
    Flashaholic Grubbster's Avatar
    Jan 2005
    Danville, KY
    Default Re: Ideal all rounder led? Need some advice...
    Not sure what would break the bank, but a U2 would fill the bill. Six light levels with a high that will out throw a L2. They can be found in BST for a little cheaper sometimes. Put in some 18650 batteries and you are good to go.
    Feb 2005
    Australia
    yeah thought about a U2 but it really is a bit too pricey. I suppose I could spend up to $150 BUT cheaper would definitely be better... The Nuwai lights look interesting, anyone have good/bad experience with them?
    Flashaholic* Somy Nex's Avatar
    Sep 2005
    Penang, Malaysia
    The VB-16 is an affordable alternative to the U2 that you can also consider. Wits End is selling a CPF version of it & you can check it out here.
    www.flashlightreviews.com also reviews it (or a prototype of it) as the "Vari-brite 16" or something like that.
    Somy Nex
    Nov 2003
    NTX
    You could always get him some basic headlamp for walking around, and then the venerable 6P for Bumps In The Night...
    Spark headlamp,712-L headlamp,D25c mini,Fenix PD35, E+Lite, Zipka, Novatac 85T.
    Flashaholic* cratz2's Avatar
    Apr 2003
    Central IN
    Well, when budget is a concern, often two quality flashlights will be cheaper than a single one with dual levels of output.
    Sounds like maybe something like a Fenix L1 or L1p for the closer in use and either the Dorcy 3D Super 1W, LEDBeam 3C light or Streamlight 3C Propolymer for more throw when scanning greater distances.
    "That's what makes SF so badass... we've got the best flashlights."
    Aug 2005
    Nashville, TN
    Quote Originally Posted by cratz2
    ...often two quality flashlights will be cheaper than a single one with dual levels of output...
    That's good advice. A single light is ideal, but except for the Vari-Brite 32L, I can't think of a great-throwing, modestly-priced, multi-level LED light.
    http://www.flashlightreviews.com/rev...vari-brite.htm
    As already stated, the LEDBeam 3C has excellent throw and is just $25:
    http://www.flashlightreviews.com/reviews/ledbeam_3c.htm
    http://www.ledbeam.com/
    A possible companion light to the LEDBeam is the Nuwai TM-301X-3, with two-level output, for $42:
    http://www.flashlightreviews.com/rev...ai_tm301x3.htm
    Both of those together are just $67.
    I definitely support the notion of two lights (without any dual level function).
    One reason is focus. If you want throw, you want a tight focus. A tight focused light will be TOO bright for any kind of close up work where you will want a broad beam.
    How about this?
    1 Streamlight ProPoly 4 AA Luxeon (great throw!)
    1 Petzel Zipka Plus headlamp 3 AAA
    The Zipka Plus is compact and can be held in the hand like a flashlight or quickly and easily slipped over the head for a hands free headlamp. It has 3 brightness levels.
    Another nice light to throw in is the Dorcy 1 AAA ($6 in the U.S.). It has a rubber collar that is easy to clench in the teeth when necessary and makes a great back up light. You can always scrounge 1 AAA battery if you have any around.
    ITS Good 4.US ...Renewable fuels create 2.46 million new jobs
    The Nuwai TM301X3 is pretty nice. I've only had mine for a few days so I can't be certain of its reliability, but being two-stage it's pretty useful. It doesn't have lockout, but the switch isn't very likely to get activated by mistake.
    Apr 2004
    Toronto, ON, Canada
    My vote would be for a Propolymer 4AA Luxeon. It has great throw and output and has 4 hrs of regulated runtime. An absolutely great light.
    However, if you want a very far throwing light, nothing beats an incandescent light such as the Pelican M6 or Streamlight Tactical Light 3.
    *Flashaholic* greenLED's Avatar
    Mar 2004
    La Tiquicia
    Pelican M6 HA: for about $100 you get a regulated LuxIII, great quality (it's a Peli, wadda you expect? ), and one of the best beams and throw out there. The Peli's M6 reflector is simply superb. Check them out at batterystation.com (CPF Specials thread).
    Feb 2005
    Australia
    Thanks for the advice, two lights does look like the better option. Given me much to think about. cheers
    you DEFINATLY need a flashlight that can throw, Streamlight 3C Luxeon comes to mind, its cheap, only like $26, lasts quiet a while on C batteries
    Banned AshA4's Avatar
    Oct 2005
    Western NY
    I would second joema for the ledbeam
    Feb 2005
    Australia
    ok, once again thanks for all the advice I really appreciate it! I'm leaning towards getting a streamlight propolymer for the throw light, seems like a great light. I just need to know whether the 3C version is significantly brighter than the 4aa version or whether the only benefit of the 3c is extended runtime? Can't decide whether the added size and weight is worth it.
    I've got a fenix l1 (R bin lux from lighthound!) on order so if it's good i'll order another l1 for my father to use for close range stuff. Those two lights should pretty much cover his needs.
    Jun 2005
    Dark Side Of The Moon
    propolymer 4AA is a very good light..I got 5 ..and I like all of.....
    Nov 2004
    DFW, TX
    You might even consider 2 lights-
    An Inova X5 for close range use around the house, and something like a Pelican M6 for throw.
    Another option would be a Streamlight TwinTask or TaskLight. Most of these models have different light output levels.
    Pel. M6 LED, SL TL-2 LED, TL-3 Xenon, Scorpion, Inova X5, SharperImage Luxeon, Gerber Infinity, Petzl Tikka, 2C Mag 3x123 KPR112, 2D Mag 7xAA KPR118, Nuwai QIII, TM115, TM311, 3rd_shift Luxeon 3C Magmod, Solitaire Luxeon, MiniMag MJLED,Mag85, MagLed 2D.
    Oct 2005
    MA
    Someone asked this before, and I'm pretty sure the conclusion was that the 3C isn't much brighter as far as overall output goes, but the beam is more tightly focused, so it'll throw farther than the 4AA. Also, like you said, the 3C will last longer on a set of batteries than the 4AA.
    Aug 2005
    Nashville, TN
    Either of the SL Proly Luxeon lights are superb. They have excellent throw for a 1 watt LED light. However they are ultimately just 1 watt, so have limited output.
    The LEDBeam has almost double the throw and double the output and is just $25. It's a great deal if you don't mind a physically larger light. It's unregulated but has pretty long run time.
    By far the best throwing commercial LED light is the LED Logic Striker VG. It has both tremendous output and throw, and has two level output. It actually out throws the UK Light Cannon, which is a High Intensity Discharge incandescent light. It's $109 from Batteryjunction.com.
    http://www.flashlightreviews.com/rev..._strikervg.htm
    http://www.batteryjunction.com/ledlostvgtaf.html
    Quote Originally Posted by joema
    only 20 mins of run time with AA lol thats hardly usable as a household/emergency flashlight. the best option is a flashlight that uses C batteries, they have very good output, and they last quiet a while even in storage. either the ledbeam 3c and SL 3c lux is probably the best option
    Flashaholic* PhantomZ's Avatar
    Sep 2004
    49N 123W Eh~
    i use to own a Wolf-Eyes M90 Rattlesnake (which is the same as the Pila GL4R) and that works well when i went for a short hike in the dark. 4 LEDs in the tailcap (which is also the push button switch) was good enough to see walking the trails. when you need to spot something upfront, turn the light around and press the tailcap and you have, i think it was, 120 lumens with rechargeables and/or 180 lumens with cr123. it throws a bit farther then the SF 6P but with ALOT more flood. the LEDs will glow green after use. you can get rechargeables for it then carry 4 cr123 for back up. charge the batteries when you get home and use rechargeable batteries around the house. the head can be used as a club. feels secure when you hold the tailcap for that purpose. the only concern i have with it is if the incan or LEDs doesnt work (broken, burnt out, etc...) both ends will not work. but its a pretty solid built light. the worst i've done to it was using 4 cr123 with the 9v bulb. and that was the very first day i got the light.
    The early bird gets the worm, but it's the second mouse that gets the cheese.
    *Flashaholic* CLHC's Avatar
    Dec 2004
    PNW|WA|USA
    If you do decide on the Streamlight 4AA ProPolymer, be sure it's the Luxeon one. Reason being is because they look much alike with the 4AA Incandescent, 4AA w/7 LED. . .
    LUX'Ottica
    Flashaholic* rikvee's Avatar
    Oct 2004
    Western Australia
    The Streamlight 4AA Propoly 1W Luxeon and the Fenix L1 are both good as gifts, close to state-of-the-art brightness and tint on common alkaline AA batteries,.
    For long shelf-life (and a bit more kick) you can replace the batts with Lithium ones, Battery Station sells them for what Duracels or Energizer Alkalines go for in Australia(!)
    Now...considering you need "throw and searching at night"-ability, if the gift receiver appreciates the even finer things in life, here's what I would get for myself:
    From lighthound.com:
    - a Surefire 9P
    - 1 spare G&P 9V globe
    From CPF-er AW
    - a DSD charger
    From Bugout Gear or CPF-er JSB:
    - 2 Pila 150s Li-Ion rechargeable batteries
    This is a truly amazing light with a beautiful, even beam, better penetration AND definition outside, and hopefully years of service with no further cost.
    I tarted mine up with a Z59 clickie and you can save on the batteries with the cheaper 17500 rechargeables instead of the Pilas.
    For a low output light an MJLED in a MiniMag works fine and last a long time....
    How much current flows through your bulb?
    Aug 2005
    Nashville, TN
    Quote Originally Posted by pr5owner
    The Striker-VG is mainly intended for 2x CR123A lithium batteries. The AA option requires a conversion kit. You don't judge the light's overall utility based on a secondary battery option. It's an emergency fallback. E.g, the Peak CPF Special is designed for RCR123A and only produces about 25% output on non-rechargeable batteries.
    He's not looking for an emergency light, but an LED light with long throw for searching property outdoors.
    You're right the LEDBeam is a good choice -- that's why it's already been mentioned.
