AuroraLite
Hi, all.
This is the dummy reference guide for making a Streamlight Batonlight modded with a luxeon I using 2 AAA batteries. As like other Dummy Reference Guide, it is by no means an official guide for making this cool mod, but more as a reference to dummies like myself.
This Batonlight originally hosts 3 5mm leds which is only fair in brightness. But I really love the form factor and did EDC it once in a while. IIRC, from Craig's Led museum, there was a cool story about how this light could withstand 'highway traffic' for a few hours on the ground and still was functional afterwards. After the mod, the Batonlight does give a much higher level of bright light(see the end comparison pictures) and although the runtime is expected to be shorten, it is a fair tradeoff for what it's worth.
The Parts you will need:
-1 Luxeon I led, preferably a RxxH or RxxJ bin.
-Emitter board, 2 connectors and MadMax Lite convertor board from Shoppe
-Some really thin copper sheet (or any metal sheet that is thin and pretty good in conductivity)
-One thick piece of paper w/ aluminum foil or a solitaire reflector
Recommended Tools:
-Must haves: Solder iron, solder, sandpaper/dremel
-Good to have: solder paste, toothpick
SLBatonlite001
Thank you to CPF, I'd learn this tip that actually 2 AAA batteries measured almost identical length to 3 N cells. And as if it was meant to be, most boost circuit found in the Shoppe(such as BB, BBNG, Madmax lite) could be fitted into the head area with ease.
SLBatonlite002
Here are the leds taken out from the front end of the light. It is probably the easiest process for retrieving the 'light engine' (other mod process often time involved hairdryer, hammering, refrigerator, photon torpedo….just kidding :nana: ) Simply twist, and the front lens/protector comes right off.
SLBatonlite003
Now, if we were to dry fitting the MM lite board into the front end of the body tube, you will find that it is actually a perfect fit, and it rests nicely onto a ledge for the negative contact for the original leds. And the coolest part is the front lens/protector could be screwed in and all the electronic components are just within the diameter of that front lens/protector…
But for the emitter board(which will be fitted into the tube of the front lens/protector), we do have to use a dremel or sandpaper to grind down the diameter to make it fit. Take extra care to not ruin the holes on the emitter board or we might render the board useless.
SLBatonlite004
If you have read the Dummy Reference Guide to Minimag Modding, then basically it is virtually the same as constructing a Sammie. And for this mod, you don't even have to worry too much about the precise height of the Sammie(like those for Minimags), just really short-stack it and make sure the top and bottom board are parallel to each other.
SLBatonlite005
For the negative contact, since it will not be like Minimag where the top emitter board could be served as a conduit, we will solder and clip a very thin strip of copper to the bottom of the converter board to make the negative contact from the negative contact on board onto the flashlight body.
SLBatonlite006
Once completed, this is how it will look when fitted into the body tube of the flashlight.
SLBatonlite007
Here we try to cut a 'tunnel' from a thick piece of paper to mimic a reflector for the light. It is a test and trial process. But once you get that right, make sure you mark down the measurements.
SLBatonlite008
This is how the light will look when everything is fitted together. If you got the measurement down, then cut out some aluminum foil likewise and place that foil in front of the paper to make it even more reflective.
SLBatonlite009
Viola! You are done! :goodjob:
SLBatonlite010
The original SL Batonlite beamshot
SLBatonlite011
Setting camera setting, the SL Batonlite with the lux Sammie inside and the aluminum foil reflector, more brightness in a more focused beam.
****The End****
As always, thank you for reading and I hope you will have fun modding this cool batonlite into a bright lux modded model. :naughty:
Recommended Tools:
SLBatonlite001
SLBatonlite002
SLBatonlite003
SLBatonlite004
SLBatonlite005
SLBatonlite006
SLBatonlite007
SLBatonlite008
SLBatonlite009
SLBatonlite010
SLBatonlite011
****The End****
