pedalinbob
I have a finished basement, and have been trying to decide if I should leave the heating vents open to heat it a bit, or to close them (I have forced-air natural gas heat).
My instinct says to close the vents (only 2 of them for ~800 square feet of finished area), concentrating the heat on the more-utilized main floor.
If I close the vents, the temp hovers around 60 degrees. If I open them, the temp settles around 64-65 degrees.
I use the area sometimes--mostly for exercise, or doing small projects. I don't mind it being a little cooler.
Am I better off heating all living areas? Is it possible that heating the basement will cost no more (or possibly less?) than only heating the upstairs?
I have searched all over the internet, and found no good answers.
I suppose I could simply open the vents for a month, then close them for a month and see what happens...but, outside temp variations could skew the results.
Bob
Bob
