I was in the same predicament, always wanting more light out of small lights!!
My host was the E2D Defender....
I bought a P61. Thats it, just the P61.
Be very patient, dig all of the white stuff that holds the bulb in the "hole" of the reflector. Next get a sharp razor blade and cut the adhesive holding the plastic base onto the P61 reflector. Now that you have that reflector off, you should have a decent looking Lamp assembly. Your not out of the woods yet.
Next you want to take your dremel, now you can go ahead and advise against this, but.... You have to dremel away the tip of the bulb very carefully with the sandpaper drum attachment. Just do it little by little, the lamp wont fit into the reflector without taking a lil off the top. Make sure you dont dremel to much though or else you'll have to start over, a $30 mistake.
Now, you'll notice it still doesnt want to all fit together! Well, put your cuttin disc on your dremel and shave lil by lil off of the battery springs until they fit.
Ahhhhh..... Now turn on your 120 lumen E2D, what a donut hole!!!
No worries, just add some Mag hotwire shims to the lamp assembly until it gets the focus you like.
Now youve got a bad a** little pocket rocket that begs for action. Please note, that this set up can't be ran for the full runtime. I havent tried it but I am almost sure the batteries will get too hot and shut off on you. The longest i have ran this set up is 5-6 minutes. Want longer runtimes, just put the regular bulb back in there ya fool! :laughing:
I use this set up when going downtown, where you know you'll only need short busrsts of lights, and yoou wanna talk about a big bright spot that suprisingly throws!
Just try it sometime when your bored, it works!
