I trying to wire a fatman with a potentimeter to power a lux V, from 3D alkaline batteries in my maglite.
Initially, I directly wired the Fatman to the luxeon to test. It was pulling 2amps from the batteries at 3.1 volts. 2A x 3.1V x 90% efficiency would be about 5.58 watts, so I was only slightly-overdriving, and since i have adquate heat-sinking, everything was good.
However, today, I wired up the potentimeter (also purchased from taskled), and put an connector in-line between the emitter and the driver. Dimming functions worked fine but I noticed that the output was noticably dimmer. So I make sure that the potentenmeter is set so that the output is the brightest, and dialed the trimpot on the fatman all the way clockwise to increase output...still dimmer than before. I measured the current going to the emitter...only about 500ma. I thought that was strange, so I added a temp 4th battery (thinking that my half-depleted alkaline batteries couldn't supply enough power)...still only 500ma going through the emitter.
Can you guys help me out with my first mod? Is it a problem with the batteries not being able to supply enough current? Or would the in-line connector to the emitter be adding resistance? Is it a problem with the Potentimeter? Or is it a problem with the fatman board? or anything else?
Please...:help:
Please...:help:
