Hi - I'm kinda new and wondered if you guys could help me with the following questions...brought about by wandering around the site
1. The brightness bin code for luxeons (R, T, etc) - is this another way of describing the efficiency of the led? In other words, the higher rating is correlated with higher efficiency and that all the led's in a 1 watt category for example, would draw the same current.
2. When we worry about frying an led because we want to use a rechargeable li ion, is there a formula to determine if we are close. The H bin led's seem to be a good choice for rechargeable li ion (3.7v) batteries which implies there is about a 0.7v tolerance. Or is it really that the higher voltage means that together with the increased amps, we are overdriving the emitter and at some point it fries. Is there a rule or guideline on how much you can overdrive before frying?
3. Concerning 3v rechargeables - if I want to minimize the number of chargers, it would seem that you could use the 3v rechargeable charger (which I believe terminates at 4.4v) with a protected 3.7v RCR123 (for example). The protection circuit could prevent the 4.4 v from harming the rechargeable battery - or would it prevent it from charging in the first place.
Sorry if any of this is unclear or just plain dumb.
Sam
Sam
