You might want to check out the Browning Black Ice Xenon/LED flashlight. It usess 2x123A cells, has a bank of 6 LEDs and a Xenon Incan bulb. Press the switch and two bight red LEDs provide night vision preserving light. Press again and two Blue LEDs take over to allow for blood tracking, the blood absorbs the blue light and appears as black. Press again and two bright white 5mm Leds provide good close range flood light. Press again and the High pressure xenon bulb puts out a bright focusable throw beam.
The light lasts for about 25 hours on the LED bulbs and Two hours on the xenon bulb.
The only down sides to this light is that you have to press the switch five times to cycle through all the options to turn the light off. Also with the 5mm LEDs being in the reflector, there are lots of artifacts in the Xenon beam, especially when the light is defocused for flood. But the white LEDs should be adequate for close up flood. Of course the beams will be broken up by the foliage anyway.
They come on two camo color schemes and can be had for about 50 bucks, less if you shop around. The black ice series is a range of Browning flashlights so be careful to pick the option for the combo light. It really is a cool flashlight.
