cratz2 said:For what it's worth, I've tried a lot of different combinations and right now, a 2 cell Vital Gear body with the TW0K-modded BOG module run on 3.7V R123s leaves me completely satisfied.
Yes, it will fit, and the plastic lens will not be a problem.adirondackdestroyer said:Paul (or someone else who knows),
I have a G2 with a stock bulb (65 lumens), can I use the 175 Lumen G90 in my G2?
I've never done a controlled runtest, but I'd say about an hour on my 1400 mAh Wolf Eyes 168B cells. No, that doesn't contradict the 1.2A figure above; the 1400 mAh rating is provided at the 0.2C discharge rate. Discharged at 1C, capacity will be less.adirondackdestroyer said:Also, how is the battery life with the 175 lumen G90?
cratz2 said:Glad to hear you're alright, weaponlight!
Yes, the first couple non-modified BOG modules I used were both quite tinted, one yellowish and one violet but the particular TW0K on this modded BOG gives the best color rendition I've ever had in an LED light. I absolutely will never sell this module.
It is absolutely outstanding!
Paul_in_Maryland said:Yes, the G90 high-pressure is my everyday lamp, used in a Surefire Z44 head with a Surefire orange traffic cone on my "crossing the street in DC" flashlight. I power it with a pair of Wolf Eyes 168B cells (1400 mAh).
The G90's beam is whiter than Surefire's and just as round. I'd say it has about 80 percent the throw of a Streamlight TL-3, 75 percent the beam width of a Wolf Eyes 9V. In output, it's more than a P90, less than a P91. For a 9V xenon light I'd never go back to 105 lumens.
G&P uses the same name (G90) to denote the original 9V lamp assembly (105 lumens) and the high-pressure (175 lumens). It's ridiculous! Lightound and Emillion sell the 105-lumen version. The high-pressure G90 won't say "high pressure" or "HP" on the reflector flange unless you buy the Digilight version. The cheapest way to buy a 175-lumen G90 is to order one from TradeDigit's eBay store; about $16 shipped, I think.
I also like G&P's G5r 3.6v 70-lumen lamp. I use it in a 2-cell body with a single 168B cell. Think of it as the little brother of the 175-lumen G90; same characteristics, but it draws more current and can't be run on an AW protected cell.
Paul_in_Maryland said:You'd need two rechargeable 123A cells (RCR123A). I can't recall whether protected RCR123A cells will work; the lamp draws about 1.2 amps, I think, so probably not. In that case, you're stuck with unprotected lithium ion cells, something I personally wouldn't do.
From Emillion. That's the only source I know of.Raoul_Duke said:Does anybody know where I can get a "G&P's G5r 3.6v 70-lumen lamp" Please.
a99raptors said:Does anybody know if a P90 can run fine with 2 protected 123s?
