trivergata said:
I'm planning on swaping out my Jeep's dome light with a selectable red/green/white Lux 3 set up. I know we use converter boards in flashlights to maximize battery life, but is there any reason to use anything other than simple resistors in an automotive setting, where battery life is not really a concern?
Josh
Let's assume 700mA to the Lux3's. Lux3 Vf will be 2.5 - 4V depending on colour etc. So, best case you need to drop about 13 - 4 = 9V at 700mA = 6.3W!!
Worst case 14.4 - 2.5 ~ 12V x 700mA = 8.4W
That's a lot of heat in either a resistor or linear regulator.
I'd highly recommend a buck converter.
AND, what happens if you leave a door open and the dome stays on for a day or night and you're pulling 0.7A -> flat battery. This is definitely a real scenario when camping etc. That's the original reason I development my buck driver for my own 4wd dome modules.
george.
