Prometheus
Results 1 to 30 of 30
Thread: DORCY METAL GEAR - what's the catch?
    Default DORCY METAL GEAR - what's the catch?
    The Dorcy Metal Gear flashlight reviewed here:
    http://flashlightreviews.com/reviews..._metalgear.htm
    Sounds too good to be true.
    I see it doesn't have any power regulation, so it dims gradually as batteries go flat. And there might be some QC issues with bulbs and reflectors not being perfectly centered.
    But c'mon, only $19 for this light? What ELSE is wrong with it that I'm not catching on to?
    Flashaholic* AtomSphere's Avatar
    Aug 2004
    Edmonton, Canada
    Default Re: DORCY METAL GEAR - what's the catch?
    yeah... pretty irrisistable when i came across it in an electronics store recently. If they make 3watters, i'll definately buy it! price is great
    I have one and it has a tighter and whiter beam (more throw) then the original dorcy 3AAA. It also has the anti-roll body. It's a descent light. I use it around the house for odds and end allot since it uses aaa's.
    *Flashaholic* Flying Turtle's Avatar
    Jan 2003
    Apex, NC
    If you don't mind it being larger than it could be, and that it has a reverse clickie, I can't think of a catch. Mine has a great tint and out-throws my old Arc LSL. Most folks here don't care much for 3 AAA lights (me, too), but I made an exception for this one. I've been running rechargeables. It's my back door, light up the yard light.
    Geoff
    You can also replace the battery pack with a Li-ion rechargable. The LED is also very easy to replace if you happen to have a better LED laying around.
    Quote Originally Posted by LeDfLaShEr
    A drop in, or would I have to machine the casing? IF a drop-in, what battery part # works?
    Is this something I'd likely want? I'm not so much looking for a cool chassis for modding - just the best under $20 out of the box package. Is there a good reason to swap out the LED in that case?
    Thanks for the feedback!
    Dec 2005
    Clifton, NJ
    I was showing mine to a flashlight dealer at the last gunshow I went to, and it had more throw and appeared brighter in general then the 3watters he had for sale. Even he was impressed with it.
    Flashaholic* cratz2's Avatar
    Apr 2003
    Central IN
    Hrmm... I've owned a few of the Metal Gears... two were good right out of the box and actually one was outstanding! The other three I was not impressed with as the tint and brightness just were not good. As mentioned, it is quite a bit larger than it needs to be.
    Assuming you get a good tint, the only real issue I have is the beam is quite ringy as with the Inova lights. The Sam's Club Element has a perfect beam and the reflector looks very similar but since Doug did the review of the Element and only got a 30 minute runtime (to 50% brightness) I can no longer recommend them even though the Element starts out twice as bright as the Metal Gear.
    The star is easy to swap on both the Element and the Metal Gear but if you are happy with the tint, and you don't want to change it to a Lux III, there's no real reason to swap it. And on the LiON cell, someone, I think 3rd Shift, listed details on how to mod the black plastic 'resistor holder' to make it shorter and allow for an 18650 cell to be used but I also found that AW sells an 18490 LiON cell that should drop in the 3xAAA lights. It's rated at 1350 mAh, but that's at the higher voltage so I'm not sure if that would give longer runtime than 3 850 NiMH cells.
    Overall, for under $20, the Metal Gear is a very decent choice. There's also the Dorcy Super 1W that runs on a 123 cell and there's the Dorcy 3D Super 1W that runs on 3 D cells and gives almost a day of runtime..
    "That's what makes SF so badass... we've got the best flashlights."
    Nov 2004
    Huntsville, TX
    check out this link I started awhile back about some mods to one of these
    http://candlepowerforums.com/vb/showthread.php?t=102003
    Dec 2004
    Earth
    Does Dorcy have a website?
    Quote Originally Posted by TKC
    http://www.dorcy.com
    Aren't you glad you asked?
    Okay, I bought one at WalMart today. Definitely worth $19, but not as awesome as I expected.
    Just a wee bit disappointed about the beam spread -- much wider than I would have liked. A little narrower beam would greatly increase the throw. Since I sometimes use my old 2AA MiniMag on tight focus as a signal light, this would be a good thing.
    Oh, and one funny thing I noticed on the warranty, as stated on the package:
    ...If product is defective, please return to Dorcy for repair or replacement. Dorcy reserves the right to substitute product of equal or lesser value if returned product is not available.
    Product of equal or LESSER value? I hope I never have to take advantage of that warranty! Gotta be a mis-translation.
    Apr 2003
    Central IN
    Yeah, well, a Lux I driven on 3xAAA cells with a resistor and a relatively small reflector is only going to throw so well... And honestly, I think it does a pretty decent job in the throw department. Personally, I'd rather have a wider hotspot or a brighter spillbeam so that just shows you can't please all the people all the time.
    Also, some come with R-bins and some come with Q-bins. A good R-bin is pretty impressive and some of the Q-bins aren't too shabby. One of the most recent ones I got was very disappointing. If I was buying it for use (rather than to use as a mod host) I would have been quite displeased.
    I also popped a TY0K (or maybe it was a TYAK) Lux III in the Metal Gear and bypassed the resistor and it was quite impressive... very nearly as bright as a Inova T3 but with a smoother 'ring section'. My point is, I think the light itself is capable of very respectable throw, but between a potentially sub par Lux I and the resistor, it may not live up to it's potential.
    The switch on the Metal Gear is fairly poor.
    Quote Originally Posted by lee_rimar
    thats probably the most unprofessional website ive seen from a well established company
    Apologies for the pathetic website. We have a new run ready to go which should be up by the end of the month with some new cool products.
    Flashaholic* parnass's Avatar
    Nov 2005
    Illinois, USA
    Quote Originally Posted by pr5owner
    At least it loads quickly, without any annoying Flash animation or music. It is simple to follow and the photos are clear.
    Quote Originally Posted by AlCanada1
    ... We have...
    Hi, AlCanada1. From the first person plural quote above, I guess you work for Dorcy. Good to know a contact here.
    What's your take on the apparently uneven quality of these lights (some users have several and report considerable variety) and the funny replacement policy described in the warranty statement?
    Aug 2005
    Nashville, TN
    ...Sounds too good to be true...I see it doesn't have any power regulation...But c'mon, only $19 for this light? What ELSE is wrong with it that I'm not catching on to?
    I had a Metal Gear; it's a good light for the money, but IMO it's out classed by the Fenix L1, Dorcy Super 1W, and Streamlight Propoly Lux 4AA. I also don't like the 3x AAA lights using a battery carrier.
    If you'ver never used a Fenix, the Metal Gear feels pretty good. But by comparison it's bigger and clunkier, and the sharp edges tend to scratch things.
    The Metal Gear is a little cheaper than the above lights. However most of the time I think it's worth paying a little more for a Fenix L1, Dorcy Super 1W or Propoly Lux 4AA (which I've seen on sale for $23).
    Quote Originally Posted by joema
    ...most of the time I think it's worth paying a little more for a Fenix L1, Dorcy Super 1W or Propoly Lux 4AA (which I've seen on sale for $23).
    Thanks for the feedback. FWIW, I was just looking for impressions of this sub-$20 light for now. But by coincidence, I had already planned to get a Streamlight Pro Polymer LUX 4AA as my next light.
    Where did you find it for $23?
    Apr 2003
    Central IN
    Fox International, I think.
    Flashaholic Brightboy1's Avatar
    Dec 2005
    Utah
    Quote Originally Posted by AtomSphere
    Atomsphere: I saw a 3 watt Luxeon version at Sears on my lunch break today. I think it was about $39.
    “Those who expect to reap the blessings of freedom, must, like men, undergo the fatigues of supporting it." -Thomas Paine, 11/11/1777
    Aug 2005
    Nashville, TN
    ...I had already planned to get a Streamlight Pro Polymer LUX 4AA as my next light...Where did you find it for $23?
    http://www.fox-intl.com/
    Thanks!
    Aug 2004
    Edmonton, Canada
    Quote Originally Posted by Brightboy1
    cool. looks like i have to wait awhile for it to arrive at an electronics store here
    *Flashaholic* PlayboyJoeShmoe's Avatar
    Sep 2002
    Shepherd, TX (where dat?)
    No catch. If you get a good one... you get a GOOD one!!!
    Mine is all wrapped up in sport tape from Wallyworld and feels better that way.
    I also have Writeright on the lense of mine as I will always trade some throw for a better beam!!!
    Last edited by PlayboyJoeShmoe; 01-06-2006 at 10:44 PM. Reason: Forgot something IMPORTANT!
    http://img32.imageshack.us/img32/2640/usflaghalfmastmdwht.gif
    PBJS
    Dec 2005
    Sweden
    I was also wondering that, looking at the specs this light looks really nice!
    Don't understand why it doesn't get a higher rating, don't think there is no other light in this size that uses regular batteries that has better throw, and the no regulation is really not an issue since you get 4 hours of batterylife to 50% and a LOT more hours diminishing, which is great if youre in an emergency, in other words, great batterylife, and all this for under 20 dollars.
    I believe regular users/nonflashoholics prefers regular batteries and long batterylife instead of total regulation that can decrease the running time A LOT.
    Dec 2005
    Kingwood, TX
    I have one I got as one of my 1st lights (3 weeks ago) and it's got a reasonable beam. However, the unit is kinda big and very heavy. It's kind of awkward and doesn't have a good feel in my hand (compared to my SF U2, even my Brinkmann Maxfire). That being said, for the price it seems good to me as well. Still happy I bought it, but I won't get another one.
    Sep 2002
    Just as an aside, you can run AAA NimH in it. I haven't done runtime officially, but my little cousin used the heck out of it and didn't kill it.
    And let us remember... it's CHEAP!
    PBJS
    Break the head loose and focus it like a M*glite. I too got one that was not as tight as my first... started messing with it and found that the head is glued in place and some are glued in the wrong position. Shouldn't affect water proofing... there is an o-ring underneath. Worth a try IMHO!
