The problem with most of those LED moon kits you find online is that they use 5mm LED's and cast a very unatural spotlight effect on the tank. Have a look at my custom made plywood aquarium hood which incorporates two Luxeon I blue LED's. It was a very simple mod and the result is very pleasing to the eye and very natural looking too due to the evenly balanced flood of light in the tank. The behaviour of the fish at night is noticeably different, and for the better in my opinion. It certainly reduces the sudden shock of night and day when the lights come on and off. Anyhow back to the topic of LED's, have a look at the pics below to see how it was done.
The LED moonlight on, close to full brightness at night:
The LED's on low:
The LED's on high:
The LED's off, as you can see i simply used a piece of sheet metal to sink the heat a bit. Heatsinking is not a major issue in this application due to the very low current being fed to the LED's.
The wiring consists of a toggle switch and a variable resistor to control brightness, power is being drawn directly from a wal wart plug.
Outside view of the controls:
The closeup of the luxeon I blue LED, nail polish used to seal electrical contacts from moisture due to evaporation from the tank.
That's pretty much it, construction of this moonlight was fairly simple. If you've got any questions or need some pointers just let me know. I would love to see pics if u decide to tackle a project like this of your own. One thing i forgot to mention is that i leave the moonlight on 24/7 and i've been running it since the begining of last summer.
