spoonrobot
- Joined
- Aug 2, 2005
- Messages
- 396
I would like to modify my pentagonlight L2 3W with a brighter emitter. This is my first real modification to my lights and I have a few questions.
I understand a U-bin emitter would give me a decent boost in light output but I would like to know the following:
-Do I only need to replace the emitter since there is already a star with regulation hardware? Or, do I need to replace the entire assembly and install new hardware in order to regulate the LED and/or boost the output.
-Given that the new emitter would be operating at the same current as the old does it make sense that there would be an output increase without the use of new hardware?
-If I do only need to replace the emitter do I need to use some kind of epoxy to re-seat the new emitter to the star?
Here is the stock set-up:
Is the UX1L emitter from the sandwich shoppe a good replacement for the current emitter or is there a better bin to use that is readily available?
Thank you in advance for taking the time to answer my questions.
