LeDfLaShEr,
I have tested the strobe extensively for it's intended purpose.
Regarding its intended purpose, read the "Why strobe light mode?"
in the link below.
http://www.night-ops.com/Gladius-FAQ.htm
It works and works very well in the following areas.
1. When closing a gap to an opponent.
2. In sparring circumstances.
3. For getting a quick upper hand against an assailent to execute a technique and then run.
The best way I have found to get people to see the value of the strobe is to get them to volunteer to be on its receiving end in any of the above circumstances.
I have a good friend that is waiting for the black HA III's to be stock. After showing him numerous lights on Halloween night. I simply turned the Gladius on strobe from about 25 feet and started walking quickly at him, when I touched his shoulder he jumped and said, "I have to get one of those". When I tried the same exercise with one of my sons I let him hold a padded baseball bat and I started from a little farther away and added a couple of studder stops and slightly chainged my pace. The results were the same, I got him and the bat before he could swing at me.
Regarding Lognbow's post, it does seem like he follows Gladius threads and bashes the light.
In one thread he mentioned not liking Night-Ops using the term "Illumination Tool" because it seemed like unnecessary hype for something that is just a flashlight.
I took issue with that and metioned all flashlights are by definition "illumination tools" and even provided links to dictionary definitions of both terms.
The problem with his above post is the statement is a statement of opinion written as though it is a fact.
In my opinion-
Longbow's stating opinions as statements of fact is just as bad a use of "hype" as the
"product hype" he has been decrying.
These are my opinions.
You can do a search on Longow's or my name and find the thread I am referring to. I am only mentioning this so that you will know there is a history behind Longbow's post and the posts taking issue with it.
Take Care,
mtbkndad :wave:
