Hi:
I received my ARC AAA Premium version two nights ago. The first couple times I tried to activate it, it wouldn't light. Then after unscrewing the cap and reinstalling, it lit.
It appeared to be reliable after that, but then a few hours later I went to turn it on, and again it wouldn't light. I carried it over to my workbench to measure the battery and to test a replacement battery (in case perhaps the internal battery connections were intermittent), and it was quite warm! I had carried it with the twist in the on position. The brand new battery measured only 1.4V and was definitely warm to the touch. I suspected something was causing the battery to get shorted.
Sure enough, once again a few minutes later it wouldn't light, and I left it that way for a few minutes. This time the battery became warm again, and was down to 1.3V.
So then I connected it to a programmable power supply with a current limit set to about 200mA. Sure enough, the first time it shorted the power supply which went into constant current mode and stayed that way until I disconnected the circuit. After that first shorting incident with the power supply, I couldn't make it short the PS again.
Right now it lights, and I can't replicate the problem.
This is a bummer. I certainly didn't expect any problems from this highly rated light. I will likely send it back and see if a replacement shows no problems. If so, I will keep it.
But this is also unsettling because I had hoped to put in a Li-AAA for long term reliablity, but now I am afraid that this would be too risky in a light that had incidences of shorting the battery.
Has anyone else ever had any similar or other problems with ARC AAA lights?
