MacTech
Tonight, on a whim, i picked up a Photon Freedom Micro (note to self, stop buying things "on a whim"), even though i have one of the Lighthound .99¢ "Photon Clones", i wanted to see how the inexpensive "imitator" compared to the "real thing"
the difference may surprise you, it sure surprised me....
One of these lights is not like the other, one of these lights doesn't cost much...
one is a Photon Freedom Micro, the other is a Lighthound "Fauxton" clone...
these pics are underexposed by 1 stop;
$15.00 Photon;
.99¢ Fauxton;
the light on the left is the Photon, the one on the right is the "Fauxton"...
here are the two side-by-side;
Photon on the right, Fauxton on the left
as far as light intensity goes, the Fauxton is actually brighter than the Photon, the Photon also has a much more yellow color balance (the literature specifies the color balance is 6500K on the LED, hence the yellow color when compared to "normal" LED's)
so, in terms of raw power, the Fauxton actually outperforms the Photon, however the Photon makes up for it with a much richer feature set.
the Fauxton has 2 settings, momentary operation, and constant on (via a switch that holds the button down)
the Photon has a lot more settings than the Faux, first off, it has brighening/dimming settings that can be accessed from power up (hold the button down as the light brightens , release when it's at the desired brightness), power down (push the power button to turn on, release then hold down the button to dim the light, release when desired intensity is reached
it has 4 flashing settings accessed by holding the power button down;
slow beacon; one flash every 5 seconds or so
medium beacon; one flash per second
fast beacon; strobe light effect
S.O.S.; distress morse code
momentary; rapidly turn on/off the light 4 times, to exit momentary, hold until the light turns off
it also ships with a lanyard (not a fan of lanyards myself) and a rather nice multifunction clip with 3 small magnets on the base
it's also a *lot* easier to change the batteries in the Photon, no tools are neccecary, the case is friction-closed, wheras the Fauxton uses 4 jewelers screws to close the case, then again, since the Faux is so inexpensive, it'd be easier to treat it as "disposable", once the batteries die, i'll pull the LED out and pop it in one of my Minimags, and toss the rest
so, even though the Fauxton outperforms the Photon in raw power/brightness, the Photon has a cooler feature set, both lights will have a place on my keyring, the Photon is definitely cooler, due to the multiple features
$15.00 Photon;
.99¢ Fauxton;
