Guys,
This is a repost of a question from another board. I pondered putting it under the batteries section, but I put it here as it seems to deal more with surefire LED flashlights than it does the actual batteries:
Surefire 123 batteries and LED lamps
I now have quite a collection of "spent" surefire CR123 batteries from daily usage of my surefire Z2, with it's standard 65 lumen, zenon lamp.
(If your not familiar w/ the operation of this surefire lamp, one may not understand that there is an enormous waste by tossing batteries that still have alot more power to offer. Appearently, from what I concluded, the zenon lamp needs full voltage to ignite and opperate. Low battery = no light. This is very often the case, but I've also had the light get dim on occation, until it dark, but most offen it just stops working all together, until I change the cells, of couse.)
I need a bit of feedback from sure fire "LED" owners re: there usage.
Does the LED flashlight just quit working, from low batteries, or does it grow dimmer and dimmer till it's dead.
I hate tolling out these things if I can help it.
If the LED flashlights will "work" with the low voltage of the cells I pull out of my Z2, then I'll pick one up as a back up.
I also remember hearing about a "lantern" that accepted 123's, that utilized an LED array to squeeze out every last bit of juice from these things.
Any links? Your truely,
too cheap.
(he later adds):
...Keep in mind I'm looking into using the surefire line of led's. It's just my preference for torches.
I'd be actually more interested in using these in a head mounted LED arraingement. kinda like a minners helmet type thing.
I've seen nothing but crapy ones that use regular batteries.
I'm thinking that, with more homework, I may be able to come up with something I can adapt to use the 123's.
Over.
This question was outside of my knowledge base, so I thought I'd bring it over here to see if someone can help the man.
Hope I didn't violate any crosspost regs. :sweat:
Thanks!
