mdocod
I bought a bunch of 5,000mah C size cells from battery space to use in my LEDbeam... (came as Tenergy cells).. Also bought the "smart" charger they sell, which seems to do a good job..
I charged up the cells to full and put them in the ledbeam, been running it a few hours a night for the last few days to get an idea of runtime...
The NIMH seems to run this light really well, very comparable to alkalines, and the output is much flatter, but when it deminishes, it really goes...
was pretty steady with minor loss over the first 5-6 hours. then slowly started to dim out, by 7 hours it is still making light, but nothing impressive...
this run time makes sense- the ledbeam would draw *around* 1 amp at ~3.6V, so the 5ah batteries should last for about 5 hours then dim out a lot.
just thought i would let yall know my results with the ledbeam on NIMHs, the runtime is near full brightness for the first 5 hours, which is a very welcome change from alkalines.
kinda wondering if it's a good idea to continue the test and pull the batteries down to nearly nothing.
