IsaacHayes
Ok, say you had your system turn off, for whatever reason, (hard reset, power failure, etc). Back in Win9x days scandisk would run before windows loaded and would find lost data. Usualy this was jsut temp files and you'd delete instead of saving it, but sometimes files would report the size inccorectly etc and it'd fix that too...
XP doesn't do this. So what do you use to check the files on your PC after such an event? Does check disk do this? But it does a low level scan though and takes a LONG time...
