cratz2
Well, after a year of avoiding it, I finally opened up an Inova X1 today. Wasn't nearly as scary as I had feared. Did the freeze pop thing three times and it pulled apart.
Eventually, I'd like to use at least a Lux I or Lux III but for now, I popped in a B0-bin Nichia CS. It looks at least three times as bright and whiter except around the very edge of the beam where it still turns distinctly blu-ish. Someone (I think it was LED_ASAP) mentioned positioning the LED further forward instead of right at the PCB (by leaving the leads a bit longer) in order to widen the beam, of course, that would leave it a bit less intense. I think I'd have to sand down the flare at the bottom of the LED a bit in order to fit it through the little brass thingy that needs to make contact.
Has anyone done this with a Nichia CS or other 5mm LED?
Also, how much current is sent to the LED itself? I measured 170ma at the tailcap with a fresh alkaline and 210ma with a fresh Energizer Lithium. Is it just a really ineffecient regulator or is it really sending close to 100ma to the LED?
Also, it no longer works with a 'cooled down' NiMH cell at all. I had an Energizer 2500 mAh that measured 1.35v on a DMM and it wouldn't even light the LED up at all.
