LEDcandle
Just got a silicone thermal adhesive, ACC AS1803. It is only rated at 1.7 w/m*k and is classified as a thermal conductive paste.
With silver and copper being rated at 300-400+ w/m*k, is this thermal paste really good for conducting heat?
I used it to glue a few coins together to be used as a heatsink (saves me the trouble of filing the coins as the silicone is fairly thick and tends to 'even' out the surface when the coins are pressed together). But with its thermal rating, is it in fact impeding the conductivity as opposed to two filed coins connected directly?
Do I really have to get Arctic Silver Adhesive to obtain silver's conductive properties in an adhesive paste form? *edit : Ok found that they claim arctic silver is around 7.5 w/m*k. Still sounds low to me. Is it anything to do with its mass?
Also, water is only rated at 0.6 w/m*k. Why is it so popular as a heatsinking solution?
