MillerMods
A review of my latest circuit by Lunarmodule can be found here: https://www.candlepowerforums.com/posts/1229862#post1229862
It drives a Lux regardless of Vf for white at 2.1 watts with an Energizer Lithium 1.5 volt cell. It drives a Lux at 1.7 watts with a NIMH. As the Vf of the lux goes up the current will drop based on P=VI. I've measured several different senerio's using different Lux's and by adding a diode in series and using a .1 Ohm resistor and O-scope to verify drive current and drive voltage. 88% is what I get for efficiency when I do the math for power in to power out.
I have 50 manufactured PCB's ready for assembly on an order basis. I'm charging $22.00 per driver + actual shipping cost. $20.00 for 2 and $18.00 for any quanity over 3. The size of the PCB is 16mm diameter and is designed to fit the Fenix L1P. I can also build these to drive 3.2 watts from 2 cells for the Fenix L2P. The price is the same.
