Hi Peggy and welcome to CPF
A lot of questions require a lot of answers.
Yes, more LEDs make a brighter light ... IF the drive current per LED is the same AND the efficiency per LED is the same. So in the end ... when looking at the zillions of multi-LED lights out there ... more LEDs could mean the light is brighter, but you can't be sure untill you actually tested it.
Battery life will be shorter, yes.
The Luxeon LED ... there are actually three of them right now ... the LuxI (what you called the 1W light), the LuxIII and the LuxV ... where the LuxIII is basically a souped-up LuxI that can withstand more current (--> can be run brighter) while the LuxV is a larger LED and is even brighter than the LuxIII, but more difficult to focus for throw.
The runtime of a "1W-light" on 3xAAA would depend on the regulating electronics of the light, if any, and the drive current. About one to one and a half hours at max seems realistic.
And there is much much more to explain in order to fully understand what those lights are all about, and I cannot do that in just this one post, I am sorry :shrug:
Now ... to answer your purchase-related question we would need additional info:
- your price range?
- 3xAAA batteries or other batteries ok, too? Think AA or CR123
- should it be able to run on rechargeable cells?
- how tough should it be? waterproof? bombproof?
- do you want a lighjt that throws far or has more like a flood beam for close-up work or walking?
- would a "plastic" light be ok, too? Might make sense to bring the price sown, and there are some nice specimen there, too.
- size of the light?
- you want it for making light (duh!) or something else, like signaling?
Feel free to ask precise quesitons anytime ... there are zillions of lights out there, and we will find one that will meet your needs!
bernie
