The Fenix L1 v2.5 is by any stretch a fabulous light - 1 watt giving really good output but able to run on a single plain Alkaline AA battery running for 2 hours, with even better performance on Lithium AA or rechargeable NiMH AA - and I only have a plain Non-premium version..... so what's not to like? :huh:
However as a general purpose light it seems to fall somewhere in-between-y for my usage - a bit too bright for close tasks and not bright enough for true outdoors distance use.
For around the house indoors usage I seem to have settled on the 1/2watt LEDs - with a preference for the ones from AdvancedMart - which are basically less blue than those from Nuwai - one of the two of my 0.5w 1AA - AdvancedMart LED-005S has quite a large hotspot with a very usable side-spill corona - despite some earlier reliablity issues - I'm becoming more and more enamored by this light - which seems to have a fine balance between "just right" brightness and long runtime of just over 6 hours on a single plain Alkaline AA. I also like the 8LED 1AA "Xnova" New a lot - despite it being relatively low-tech and "crude" in its approach of just using more multi-LEDs - it has a runtime that seems very inefficient to me for its brightness at about 2-3hours - but again its flood-like spot and "right" level of brightness - finds it sitting in my pocket for my at home usage. I just use a rechargeable NiMH AA and recharge the battery as soon as I see the light dim....
I find that the Nuwai Q3 running on a rechargeable Li-Ion RCR123 (3.7V) gives pretty spectactular output - with a really useful beam (floody-spot). Its performance on a regular non-rechargeable CR123A is probably nothing to write home about - but it works...... Unlike the Fenix L1, the brightness on Rechargeable RCR123 is well worthwhile for outdoors and distant usage.
As an illustration for more distant usage - please take a look at my attempt at some more "Practical" Beamshots
credit for this theme should be given to particle or wave? over at flashlight-forums.com for his thread starter of The more I use my Fenix...............
