oregonshooter
- Joined
- Dec 19, 2005
- Messages
- 313
I've had this idea in the back of my head for a while and am looking for input from you guys on what the specs should be for my ULTIMATE BOV (Bug Out Vehicle) Maglite.
The image below may help or may confuse what I'm thinking of.
Basically I want to take a Maglite 3-D cell (seem to be most common) and cut it off just below the switch with only enough room to pack the new power supply into it.
The bottom half of the light will get a slug pressed into it that will thread the two pieces back together and allow access to change batteries in the top half.
The bottom cap will allow access to what ever survival gear the user wants to put in there.
The bottom half will be water proof.
So help me out here OK?
SPECS:
SPECS:
- Lamp system - Needs to be LED, long run time with a middle ground between throw and area illumination.
- Power source - Needs to be something I can find at a Bi-Mart. No rechargeables.
- Survival gear - What would you put in it? Remember we are talking somewhere in the 1-1/4"x5-1/2" size range on a three D-cell light. Will depend on the new power source, but I'm being generous and giving up a D-cell of space for it.
- Anything else I'm not thinking of?
