i remember seeing a thread today about fitting some stuff into the back end of a maglite. im not that great with flashoholism wording but here it goes. im not sure if this is the same, but would it be possible to use an adpater that fits 3AA into 1D space and then using that and then cutting the rest of the mag and making an end cap for it that will also fit the remaining part of the mag that you cut and then you can screw all 4 pieces together? it would be pretty wide and useful i suspect.
i was also wondering if anyone would be able to do this?(the cutting, making the center cap, and threading of the new parts) thanks!
