Carbonium
Want to know if your Luxeon based flashlights are regulated on not?
I figured out a simple 5 second test. No need to bust open your flashlight.
So far it quickly identified 18 of my Luxeon lights. Six were regulated and 12 were not.
Test is to be conducted in a dim or dark room.
Simply unscrew the tail cap. Push your thumb or finger where the tail cap spring was. Make sure to touch both the battery negative and the threads with the same finger. Your finger is acting as a resistor. If your light has a switch then turn it on.
1. If you can see your luxeon glow "very dimly" it's resistor or direct drive.
2. If you see no light at all it's regulated.
End of test!
PS: Let me know if you find a regulated light that glows with the magic thumb test. I have yet to find one.
End of test!
