MillerMods
I will take requests, so let me know if you need something you don't see.
I have the following designs:
-1 cell NIMH, .8 watt up to 1.7 watt, also can be designed for lithium-ion 3 watt operation but the same driver will only drive 1 watt with a single NIMH, not 1.7 watts when it's configured this way. Also the voltage bias bin for the lux is best if it is K and higher and the li-ion cell must be self protected.
-2 cell NIMH, 1 watt drive to a Lux I up to 3.5 watts drive to a lux III
-3 cell NIMH, 3 watt drive to a Lux III up to 5.5 watts to a Lux V
For boards that I don't have a layout for, I will hand cut the traces and charge 2 dollars less because they aren't manufactured. Unless you want a layout designed for more than 25 boards. I will then have them manufactured.
You may specify the diameter or dimensions of the board you would like custom built. Some drivers I can layout on as little as 10mm diameter board space.
I also give bulk discounts starting on 2 boards and up, so ask me and I'll give a quote.
My drivers are very efficient, at the very worst about 80%. Most of them are 85% to 93%.
