thefish
What is the best LED drop in for my 4D Maglite? The bulb just burned out so I figured it was a good time to make the switch to LED.
randyo said:Corrected on 1-19 for accuracy:
(The TLE-5 is not rated for 3 or 4 battery usage)
Depends on what your application is -- if you switch to a UV module, or selectable white/UV, you can do all sorts of new things with your 4D Maglitethefish said:What is the best LED drop in for my 4D Maglite? The bulb just burned out so I figured it was a good time to make the switch to LED.
