I've been really enthusiastic about the MJLED drop-in for the MiniMag 2AA (or 2AAA) my first ones were what is now known as generation 2.
Please see -
MJLED drop-in for MiniMag 2AA
So when I read about the Super MJLED at Lambda with even better brightness and efficiency I had to get some to try out.
I ordered two last Saturday Jan/14 - and they were delivered yesterday Thursday Jan/19 - great service (considering the holiday Monday) from Kevin/Lambda.
So am I now jumping up and down being all enthusastic again? :huh:
No - I am somewhat disappointed :mecry: .
On plain but Fresh alkaline AAs this new Super MJLED looks no brighter than my gen2 MJLED (#2) - and the tint is much bluer with a purple tinge.
This is for BOTH my samples of the Super MJLED.
The LEDs don't look different from my original gen2 MJLEDs.
I found one was very easy to get well centered and symmetrical in my MiniMag AA host - I used the one that would give the new Super MJLED an advantage - this host has the Lambda pre-drilled reflector and the UCL glass lens whereas my gen2 MJLED has a home-drilled reflector and the original plastic lens
superMJLED vs. gen2 MJLED (my #2)
The brightness seem about the same - if anything the gen2 might be very slightly brighter - and it's on good but used AA alkalines and the Super MJLED is on fresh alkalines.
Here are some current draw readings using 10A scale -
Duracell set open-circuit = 3.03V
PairDeer set open-circuit = 3.06V
Super MJLED
D = 0.03A or 25.7mA on 200mA scale
P = 0.03A or 22.7mA on 200mA scale
gen2 MJLED (my #2)
D = 0.03A or 26.3mA on 200mA scale
P = 0.04A or 27.5mA on 200mA scale
with these low current readings one would expect extremely/insane long runtimes - and the brightness level is about the same or perhaps a bit brighter than a typical 1/2watt LED light....
gen2 MJLED (my #2) vs. AdvancedMart 0.5w 1x CR2
SuperMJLED vs. AdvancedMart 0.5w 1x CR2
but what a pity about that blue tint of the newer Super MJLED -
they're just not as "super" as my original gen2 MJLEDs even the greenish yellow one (my #1) ........
Please see -
Super MJLED
gen2 MJLED (my #2)
