MillerMods
For those not interested in the 1.7 watt single cell driver, I thought I'd post about using it for the L2P. With 2 NIMH cells, this driver can produce a max of 3.5 watts and nominal of 3.2 watts of drive, and it will still work with one cell and the power out is halved. It runs 85% efficent, and draws 1.6 to 1.7 amps from the cells. Nice circuit for the Fenix or any other 2 AA cell flashlight you might want more power out of. I also can make this circuit 14.4mm (.57 in.) diameter so it can be used to modify a broader number of flashlights. Stock is 16mm diameter.
